Replace All Error: Tell Inventor X feat in part A is equiv to Y feat in part B?
When doing a "Replace All" command in Autodesk Inventor I'm often confronted with the error: "Relationship was placed with respect to geometry that is no longer available."
For example:
If I change Screw A to Screw B with a "Replace All" for 20 (or more) screws. Before the Replace All command I have the axis (Screw A-Axis 1) of each Screw A mated with the hole it should go in (Mate 1). I also have the bottom of the head (Screw A-Plane 1) of each Screw A to touch the face I need (Mate 2). When I "Replace All" Screw A with Screw B for all 20 instances, I get the error "Relationship was placed with respect to geometry that is no longer available." 40 instances (one instance per Mate).
I know why this is happening. Inventor doesn't know how to relate ScrewA-Axis 1 with ScrewB-Axis1 or ScrewB-Plane 1.
Is there a way I can tell Inventor "This axis on Screw B (ScrewB-Axis 1) is equivalent to this axis on Screw A (ScrewA-Axis 1)"? And "This plane on Screw B (ScrewB-Plane 1) is equivalent to this plane on Screw A (ScrewA-Plane 1)"?
This would save me so much time!
Otherwise, I'm stuck with redefining these features/mates 40 times! Which doesn't even work most of the time. And then I'm forced to delete all mates and start again!
I apologize if this has already been answered. I looked for this question/answer for a long time (and many times) and couldn't find it.
Thank you!
