Inventor General Discussion
1 Solution
Post 1 of 6
Accepted Solution
parameter function
1031 Views, 5 Replies
01-13-2013 02:50 PM
What is the proper way to write the function- inverse tan when writing a equation in parameters?
example- ((Heigth/ Run)inverse tan)
Can you tell me how to correctly write out the function inverse tangent?
thx got it
1 Solution
Post 2 of 6
Re: parameter function
01-13-2013 05:19 PM in reply to: heyjude19
thx got it
488 Kudos
298 Solutions
Post 3 of 6
01-13-2013 06:39 PM in reply to: heyjude19
You can't mark it solved unless the solution is provided!
The inverse tangent function in Inventor parameters is "atan()"
Highlighted
Post 4 of 6
01-14-2013 12:49 AM in reply to: heyjude19
For an overview of functions please take a look at;
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/1310-Autodesk1310/1946-Design_O1946/1950-Functio...
Best regards.
Inventor 2011 (x64)
Productstream Professional 2011 (x64)
Windows 7 (x64)
Product design suite Professional 2013
Post 5 of 6
12-18-2013 04:05 PM in reply to: mnthailand
The link is junk because autodesk changes the year that this is located under and the majority of the link is cut off.  If you click it you get booted to the base help page.
AUTODESK EXPERT ELITE
1007 Kudos
188 Solutions
Post 6 of 6
12-18-2013 11:02 PM in reply to: PCross99
The link is obsolete, since the online help was changed to a new format.
This is probably the page it linked to:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-EE98BCED-5623-4E3B-9E98-432C6738B081
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional newbie
The Netherlands
My Facebook Friday Pictures Archive
Using IV2016 Pro - SP1, Win7-64bit
Post to the Community
Have questions about Autodesk products? Ask the community.
New Post
Community Alert
The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
Community Alert | The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
