Inventor Forum
npt holes
4 REPLIES 4
rclement
585 Views, 4 Replies
npt holes
why isnt there a npt hole selelction in hole command but is in thread command?
would like to add the tap drill info to the hole callout
cant do that with thread command
b ob
4 REPLIES 4
rclement
in reply to: rclement
with out using the text option for threads
mark.mmlj
There is.  You have to select the Tappered Tapped Hole option.
rclement
in reply to: mark.mmlj
ha
very cool. i never even thought too look there.
brain fart
thank you
mark.mmlj
Under Tools >Document Settings >Modeling Tab >Tapped Hole Diameter you can change which part of the hole you want displayed, but I've never tried changing it myself.  I've left mine set on Minor.
