why isnt there a npt hole selelction in hole command but is in thread command?
would like to add the tap drill info to the hole callout
cant do that with thread command
b ob
Solved by rclement. Go to Solution.
Solved by mark.mmlj. Go to Solution.
Under Tools >Document Settings >Modeling Tab >Tapped Hole Diameter you can change which part of the hole you want displayed, but I've never tried changing it myself. I've left mine set on Minor.
