Export and import file between Inventor and Tekla BIM software
lis_wang
lis_wang
I need to use Inventor to work with Tekla structure software. May I know how to export and import file between Inventor and Tekla BIM software?
BeKirra
I know nothing about Tekla, but as a "solusion", a stp or sat file can be opened by inventor if Tekla can convert its model to these formats.
However, stp or sat files cannot be modified in Inventor as you want to "work" with the model.
On the other hand, Inventor can convert its models to these foramts if you can use them in Tekla.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
KevinLi-Autodesk
Hi
Don't know Tekla BIM software as well, sorry for this.
You can check the Import/Export file format that supported in Inventor and Tekla BIM, and select a format (if have) that Inventor can export and Tekla can import or Tekla can export and Inventor can import. Mostfully some neutral formats have a value to try (for example, IGES/STEP...... or maybe .dwg).
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
