Inventor General Discussion
AUTODESK EXPERT ELITE
883 Kudos
150 Solutions
Post 1 of 2
Accepted Solution
Edit Fillet Weld ...Need way to add Welding Symbol
825 Views, 1 Replies
01-08-2013 07:37 AM
I am looking for a way to add a welding symbol to an existing fillet weld.  When I am creating a fillet weld, I get a chance to create a welding symbol based on the fillet weld size.
If this is not done when the weld is created, there is no way to add this notation.  I don't have the "Create Welding Symbol" checkbox when editing an existing weld.  The only solution is to delete the weld and recreate it.
I am trying to link the welds in the iam with the weld notes in the idw. This little caveat makes it time consuming for something that should be pretty simple.
Kirk A.
Windows 7 x64 -12 GB Ram
Intel i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 301.42)
INV Pro R2013, SP1.1 (update1)
Vault Basic 2013
Hi karthur1,
You can use the Symbol button to add the weld symbol to a weld bead after the fact. The results are the same as if you were to have added it when creating the weld bead (unless I've missed something).
I hope this helps.
Curtis
2223 Kudos
820 Solutions
Post 2 of 2
Re: Edit Fillet Weld ...Need way to add Welding Symbol
01-08-2013 08:16 AM in reply to: karthur1
Hi karthur1,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Post to the Community
New Post
Community Alert
The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
Announcements
Community Alert | The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
