What are the steps to having different thickness in as part file.I tried the unique thickness but could bot get it to work
1. Revolution 1 - 5mm
2. Revolution 2 - 2mm
3. Extrusion 1 - 2mm
I try selecting different faces but no success
Cheers
Solved by JDMather. Go to Solution.
If it had worked - it would have to add the Fillets 3 and 4 that I added.
I am not sure you intended these - so if not, simply do the Shell feature before Fillets 1 and 2.
