I need to create a surface to split a solid. IS there anyway to do this?
Solved by JDMather. Go to Solution.
Yes.
Create surface.
Then select Split.
This tutorial shows some examples.
There is also Trim with Surface and Replace Face - same as in SolidWorks.
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
You may use a sketch to do the split if it is very simple.
