This may be a simple question, but I was not able to find a solution online. I am running version 2016.
I am currently trying to create a drawing in color, I have tried clicking the "Shaded" option but I want the views to look how they would when I am looking at them in the assembly. The shadded view does not show the detail that I need to display. I have watched a few youtube videos on the topic and several of the people had their projected views show up in color, but I don't know how they did it. They had the shaded option clicked.
Thank you for any help you may be able to provide,
Colby
Post what you have so far, even a screen capture so we can see what you have done.
Colby
Shaded is the solution.. BUT the drawings only use a default lighting style and won't do realistic,etc... so it won't look like your assembly unless you just insert pictures taken from the assembly into the drawing..
There is also... tools.. document settings...Drawing tab..
Change Shaded Views to..Offline Only and maybe try jacking up the resolution..
One thing I've done, is to set the background color to white. The render the image till you get it like you want it. Save as bmp or jpeg. Then insert this into drawing. With IV tan background color you'll see white around your image, but when you print to white pape, it looks fine.
