Dear Sirs,
We are studying to buy the Ultimate Suite that includes Inventor, Fusion 360 and other software, but we have a couple of weeks struggling to find a walkthrough for converting a scanned point cloud into a parametric solid. Specifically we are planning to buy a DAVID SLS-2 scanner that exports .obj or .stl point clouds. We are going to scan complex Water Pump Impellers and we need to find a way to build a parametric solid starting with the scanned data.
We have been in touch with the autodesk local representatives, but they don´t have any experience with our problem (Reverse engineering of scanned data). We have watched a bunch of youtube videos but we have been unable to find a solution within Autodesk software.
Please help us finding a solution to our requirement. (Scan the Object -> Proces the point cloud -> extract parametric surfaces and splines -> build the solid)
Thanks for your help!
Eng. David Valladares
Design and Engineering Chief
Global Motor, S. A.
ingenieria@globalmotor.net
+57 1 743 4500 Ext 222
Bogota, Colombia
Dear David
ReverseEngineering.com supports your requirements with thier certified 2017 partner add-in
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=22005804
Best Regards,
Braxton Carter |
HighRES, Inc / ReverseEngineering.com | 2746 Fay Ave Suite #200 (Merrill Lynch Bldg.) | La Jolla | CA | 92038 | USA
Phone: +1-858-488-5231 | Cell: +1-858-775-0571 | Fax: +1-858-459-5241
