- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Lien permanent
- Imprimer
- Signaler
Bonjour,
j'ai une code quel remplace le symbole nomé sur tous les pages par une autre.
Il y a une possibilite de detecter la position du symbole et placer la nouvel dans la meme position?
Voici mon code:
Dim oSheets As Sheets= ThisDoc.Document.sheets Dim oSheet As Sheet For Each oSheet In oSheets oSheet.Activate Dim oSymbol As SketchedSymbol Dim oSymbols As SketchedSymbols ' Obtain a reference to the desired sketched symbol definition. Dim oSketchedSymbolDef1 As SketchedSymbolDefinition = ThisDrawing.Document.SketchedSymbolDefinitions.Item("PE_PRÉLIMINAIRE_FR") Dim oSketchedSymbolDef2 As SketchedSymbolDefinition = ThisDrawing.Document.SketchedSymbolDefinitions.Item("PE_SOUMISSION_FR") Dim oSketchedSymbolDef3 As SketchedSymbolDefinition = ThisDrawing.Document.SketchedSymbolDefinitions.Item("PE_CONSTRUCTION_FR") Dim oSketchedSymbolDef4 As SketchedSymbolDefinition = ThisDrawing.Document.SketchedSymbolDefinitions.Item("PE_ConsigneSoudure_FR") 'create insertion point, coordinates - in cm ! Dim oTG As TransientGeometry = ThisApplication.TransientGeometry Dim oInsertionPoint1 As Point2d = oTG.CreatePoint2d(30,5) Dim oInsertionPoint2 As Point2d = oTG.CreatePoint2d(10.2, 2.2) ' Add an instance of the sketched symbol definition to the sheet. For Each oSymbol In oSheet.SketchedSymbols If oSymbol.Name="PE_PRÉLIMINAIRE_FR" oSymbol.Delete Dim oSketchedSymbol1 As SketchedSymbol = oSheet.SketchedSymbols.Add(oSketchedSymbolDef2, oInsertionPoint1,0.261799, 1, Nothing) iProperties.Value("Project", "Engr Date Approved") = Now iProperties.Value("Project", "Revision Number") = 0 ElseIf oSymbol.Name="PE_SOUMISSION_FR" oSymbol.Delete Dim oSketchedSymbol1 As SketchedSymbol = oSheet.SketchedSymbols.Add(oSketchedSymbolDef3, oInsertionPoint1,0.261799, 1, Nothing) iProperties.Value("Project", "Mfg Date Approved") = Now iProperties.Value("Project", "Revision Number")=1 End If Next ThisApplication.ActiveView.Fit Next InventorVb.DocumentUpdate(False) ThisApplication.ActiveDocument.Sheets(1).Activate()
P.S. - vous povez lui corriger si il y a une fasson de faire tout ca plus semple.
Merci.
Le titre du sujet a été modifié par un modérateur pour faciliter la recherche. Titre original:
Detection du symbole et leur remplacement dans la meme position par un autre
Résolu ! Accéder à la solution.
