Communauté
Inventor - Français
Bienvenue sur les forums Inventor d’Autodesk. Partagez vos connaissances, posez des questions, collaborez sur des idées, et explorez les sujets Inventor populaires.
annuler
Affichage des résultats de
Vouliez-vous dire :
i-Logic- Impression plusieurs dessins dans une seul PDF
1 RÉPONSE 1
RÉSOLU
Répondre
Message 1 sur 2
denis.semeniuc
187 Visites, 1 Réponse
Bonjour,
Est-ce que possible de faire imprimer plusieurs pdf dans une seul pdf.
Cest une code quelle je utilise pour umprimer les pdf:
'------start of iLogic-------
If ThisDoc.FileName IsNot "" Then
		oPath =  ThisDoc.Path
		oFileName =ThisDoc.FileName(False) 'without extension
		oRevNum = iProperties.Value("Project", "Revision Number")
		oProject = iProperties.Value("Project", "Project")
		oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
		'oDocument = ThisApplication.ActiveDocument
		oContext = ThisApplication.TransientObjects.CreateTranslationContext
		oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
		oOptions = ThisApplication.TransientObjects.CreateNameValueMap
		oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
		Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
		Dim oSheet As Sheet = oDoc.ActiveSheet
		Dim oSymbol As SketchedSymbol
		Dim oSymbols As SketchedSymbols
		'Define the drawing
		Dim oDrawing As DrawingDocument
		oDrawing = ThisDoc.Document
'		Dim oSheet As Sheet
'		oSheet = oDrawing.ActiveSheet
		Dim lPos As Long
		Dim rPos As Long
		Dim sLen As Long
		Dim sSheetName As String
		Dim iSheetNumber As Integer
		''find the seperator in the sheet name:number
		lPos = InStr(oSheet.Name, ":")
		''find the number of characters in the sheet name
		sLen = Len(oSheet.Name)
		''find the sheet name
		sSheetName = Left(oSheet.Name, lPos - 1)
'-------Options-----
		oOptions.Value("All_Color_AS_Black") = 0
		oOptions.Value("Remove_Line_Weights") = 1
		oOptions.Value("Vector_Resolution") = 400
		oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
		'oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet
	'------get PDF target folder path---------------------------------------
		oFolder2 = Left(oPath, InStrRev(oPath, "\")) & "PDF"
		' Add an instance of the sketched symbol definition to the sheet.
		For Each oSymbol In oSheet.SketchedSymbols
			If oSymbol.Name="PE_RÉFERENCE_FR"
					oFolder = oFolder2 & "\" & "Reference"
			ElseIf oSymbol.Name = "PE_COMMENTAIRE_FR" Or oSymbol.Name = "PE_PRÉLIMINAIRE_FR" Or oSymbol.Name = "PRÉLIMINAIRE_FR" Or oSymbol.Name = "PREMILINARY_EN"
'				oFolder = Left(oPath, InStrRev(oPath, "\")) & "Preliminaire"
				oFolder = oFolder2 & "\" & "Preliminaire"
			ElseIf oSymbol.Name="PE_SOUMISSION_FR" Or oSymbol.Name = "TENDER_EN"
					oFolder = oFolder2 & "\" & "Soumission"
			ElseIf oSymbol.Name="PE_CONSTRUCTION_FR" Or oSymbol.Name = "CONSTRUCTION_EN"
					oFolder = oFolder2 & "\" & "Construction"
				Else
		 Next
	ThisApplication.ActiveView.Fit
'________________________________________________________________________________________________________________________
		'Check for the PDF folder and create it if it does not exist
		If Not System.IO.Directory.Exists(oFolder) Then
		System.IO.Directory.CreateDirectory(oFolder)
		'Set the PDF target file name
		oDataMedium.FileName = oFolder & "\" & oFileName & " - Rev" & oRevNum & ".pdf"
		If System.IO.File.Exists(oDataMedium.FileName) Then
			Dim fio As New System.IO.FileInfo(oDataMedium.FileName)
			If fio.IsReadOnly = False Then
				MsgBox(fio.FullName & " Read Only")
				Else
			'System.IO.File.Delete(oDataMedium.FileName)
			'System.IO.File.SetAttributes(oDataMedium.FileName, oAtts)
		'Publish document
		oPDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
		'OpenFolder
		Shell("explorer.exe /Select," & oFolder, vbNormalFocus)
		ThisDoc.Launch(oDataMedium.FileName)
Else
	MessageBox.Show("Save Document", "Save", MessageBoxButtons.OK)
1 RÉPONSE 1
Message 2 sur 2
ThomasB44
en réponse à: denis.semeniuc
Salut @denis.semeniuc
C'est possible avec Adobe Acrobat Pro si tu combines les fichiers produits en un seul.
C'est possible avec Inventor si un seul dessin comprend toutes les feuilles à imprimer et que l'option de sortie du PDF est réglée sur "Toutes les feuilles" (kPrintAllSheets)
Comme indiqué, la commande oPDFAddIn.SaveCopyAs, converti le fichier en PDF.
Il faudrait créer un dessin temporaire et y copier toutes les feuilles de tous les documents souhaités, puis exporter en PDF.
Mais cela peut poser d'autres problèmes comme par exemple les propriétés du dessin indiquées dans les cartouches, le numéro de la feuille, etc...
Thomas
Mechanical Designer / Inventor Professionnal 2023
Inventor Professional EESignature
Publier dans les forums
