Inventor Forum
Wrong Hole / ThreadedFace thread info
5 REPLIES 5
billing5GPFL
212 Views, 5 Replies
Hello forum
i have a part with 2 holes as shown in the pictures
the info for the one hole M10 are correct
the info for the 1/4-20 are not
ThreadedFace.Geometry.Radius is correct in both cases, the hole are actual that size
in the 1/4-20 ThreadInfo i looks like the parameters major / minor which are the diameters have values from the close to the radius.
or inventor did the hole double the size or ...
i hope i explained that correctly.
pictures and file attached
5 REPLIES 5
blandb
in reply to: billing5GPFL
Matches the Threads.xls table in design data:
The document settings control the appearance of the tapped holes...It is set to Minor diameter by default.
Autodesk Certified Professional
billing5GPFL
in reply to: blandb
no arguments there, you are correct about that but
notice that Geometry.Radius (thats the actual hole Inventor puts on the model) is 0.2 and MinorDiameterMin/Max is also 0.2 or near it, perfectly normal, but the one is RADIUS and the other is DIAMETER, so i am guessing one of them is wrong
blandb
That little window, I'm not certain it is converting the Inch units? You have Minor Diameter = 0.196 inches x 25.4 = 4.9784 mm diameter or 2.4892 mm Radius (which is what is measured). The geometry.radius appears to be displaying CM, so 2.4892/10 = 0.24892 cm.
The metric version appears to all be converting correctly. Just not the inches in that little program?
Number in the 1/4-20 is imperial: inch.
Debugger Watch only show number.  No units.
billing5GPFL
in reply to: blandb
Hey, yes you are correct
they are in different measuring units !
