Wrapping text to surface
I can't get my text wrapped around this cylinder that I have and I need help! I have attached a picture of what I am trying to do.
kelly.young has converted your docx to jpg for clarity and removed file
Accepted solutions (3)
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous are you trying to make a curved text on the flat space between the green and yellow line?
If so you have to create a 2D Sketch with a drawn line for the text to wrap to.
I'm assuming you are trying to project to the text onto the side of the cylinder instead for an Emboss?
Please select the Accept as Solution button if a post solves your issue or answers your question.
Xun.Zhang
Hi!
Try to use arc instead of a full circle which means you can trim bottom circle.
Hope it helps!
Xun
admaiora
Hi Joints,
do you mean something like this?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Thomas_Savage
Hello @Anonymous,
I have attached a screencast how to place Geometry Text on a curve.
Thomas.
Edit: Sorry @admaiora you had not posted the YouTube video when i came on the post.
Thomas Savage
Design Engineer
kelly.young
Autodesk Support
Autodesk Support
@Anonymous & @Anonymous did any of the great examples help you with your text?
