When I create a sketch with text, the text wraps around inside the text box I created (1st attachment). When I extrude that text it flat lines extending the text off to the left and right of the part (2nd attachment).
How do I make the extruded text wrap like the sketch so all the text stays on the part?
Solved by Xun.Zhang. Go to Solution.
Hi @Anonymous,
Just simplify add linefeed in your sentence, check out the sample file which was built in Inventor 2018 and hope it helps!
Hi @Anonymous,
Compatibility pack is allow you to open future version files, you have to upgrade Inventor to 2017.4 at least and the compatibility pack was installed automatically.
Anyway, here is the 2017 file. Open it and edit the sketch and edit the text, you will find that those text are in different line.
Hope it helps!
Another way to control word wrap in sketch text is to turn on the Text Box feature. This changes from an insertion point to a rectangular construction line box around the text, which can then be precisely controlled by dimensions and constraints.
The Text Box is turned on/off either by right clicking the text, or by the control button in the text editor dialog:
Sam B
Inventor Professional 2018.2.3
Windows 7 SP1
