Wire and Harness Report Generator Virtual Part Reference
jack.bonnellPKXNS
jack.bonnellPKXNS
Hi, I have been trying to make the wire and harness report generator output the instances of virtual parts used in the harness, specifically for a loom I would like it to put the part numbers for each loom into the table.
Here is an example of one of the looms.
I have worked pretty extensively with the wire and harness report generator in the past. However, no matter what I try I can't seem to figure out how to reference the looms.
Here are photos of some setting I have tried, but I wasn't able to get it to work.
These settings are just trying to see if I can capture any of the Loom's properties
This is the output of that config from a harness that has looms in it.
Any help would be very much appreciated. I would be happy to try anything anyone suggests.
jack.bonnellPKXNS
As far as I can tell, this is not possible. I found this post from 9 years ago trying to address a similar issue and the only solutions they had were work arounds for anyone interested.
Cable and Harness - Virtual parts in BOM - Autodesk Community - Inventor
