Which Situations To Use Inventor Reset Utility?
lkirit2000
Advisor Advisor
lkirit2000
Hi
I am need to know what is purpose of inventor reset ? Which situations we need to reset ?
Rgds
Kiri
kelly.young has edited your subject line for clarity: Inventor Reset
johnsonshiue
Hi! Inventor Reset Utility is a tool to restore all registry keys and options back to install default. Some users share a computer with others. Sometimes the system level settings are changed and the next user may not like it. This is a quick way to restore the default settings quickly.
Occasionally, the settings are changed possibly due to 3rd party applications or unfound bugs leading to weird behaviors. This reset tool also helps restore the settings and the weird behaviors will be gone.
Many thanks!
Software Test Engineer
Fleiscal01
Whats the process of resetting? It won't let me delete my dimensions and I have a feeling I need to do the reset
johnsonshiue
Hi! I could be wrong but your case would not help by resetting all the settings. Inventor Reset Utility helps restoring all the settings in Inventor back to install defaults. But, your case sounds more like a corruption to me.
Many thanks!
Fleiscal01
interesting! I found the reset button and was able to delete my dimensions after that. Are there any other indicators that it might be corrupted? I'm using it for school (student license) so I'd rather make sure its right now than run into further issues later
johnsonshiue
Hi! I am not sure. It sounds like a bug. Whenever Inventor Reset Utility helps, it means there is a bug. It should not be needed in the first place. If you can reproduce the behavior, please let us know.
Many thanks!
