when I import a dxf into a sketch nothing shows up (worked in the past)
I am trying to import a dxf into an inventor sketch and when I do nothing shows up in the sketch and there is no error messages. this has worked in the past and has never not worked. I saw some similar posts but they where for much earlier versions and all suggested solutions didn't work. so far i have tried restarting my computer, opening old dxfs that worked in the past, checking for updates, I also tried the solution quoted below. any advice and help is very much appreciated!
Press [Windows] key to open the Windows' start page
2. Type "cmd" to find "Command Prompt" > right mouse click on it > select "Run as administrator"
3. On "Administrator: Command Prompt" window, type (no quotes) "cd c:\program files\autodesk\Inventor 2014\bin"
4. Type (no quotes) "inventor.exe /install"
5. Press Enter
6. Wait for 1 min (inventor will be executed background then exit silently)
