When create project missing This PC
RadoG
RadoG
When create project missing This PC i see only user folder. I want chose folder from This PC. But This PC(този компютър ) missing.
johnsonshiue
Hi! I suspect this is Windows User Profile related. Somehow Windows blocks Inventor from seeing certain folders. Try running Inventor as Admin (right-click on Inventor icon -> Properties -> Compatibility -> check "Run as Admin").
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
RadoG
I tried this advice but without success. then I reinstalled the program but without success the problem is not solved.
johnsonshiue
Hi! It seems that you are running Inventor on a virtual environment or remotely. The dialog shown in the image seems to be File Open dialog. Did you check if File Explorer in that environment behaves the same?
Many thanks!
