What is this thing with the wobbly line?
robin1_hague
robin1_hague
I don't even know what it's called to go looking for it in the forum or the documentation! But what is this line about when you end up catching right click and dragging? It has been around a while and drives me mad, to no apparent benefit! Am I missing what it's for?
robin1_hague
Looks like this!
Frederick_Law
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-4B081B74-45EA-451E-84BE-9FFE0E2ACAE3
Gesture in Marking Menu.
Mark Mode and Gesture Behavior
Draw a mark with the cursor as you move it toward a menu item, and then quickly release the mouse button to select that item. This action is also called gesture behavior.
After you become familiar with the marking menu layout, this technique helps to execute commands faster.
robin1_hague
Ah I see! Can I turn it off?
j.palmeL29YX
I guess you're talking about the marking menu. It is implemented in several Autodesk products.
>>Here<< a video from the Fusion 360 help, it explains IMO well what happens.
Jürgen Palme
Frederick_Law
I don't think so.
You can try disable Marking Menu.
Turn on "Use Classic Context Menu"
robin1_hague
Ah worth a look! Well it's a relief to know what it is! Thanks!
