What is the difference in FEA?
16020227DHP
Message 1 of 10
16020227DHP
I wonder what is happening between these two set
One is send from my professor, the other one is my set trying to copy these conditions
3 questions:
-Can someone tell me what can i do get the same results from "zestawienie" into "zestawienie_500"?
-Also which one is more proper for FEA study?
-And how to fix eventual mistakes?
Replies (9)
Message 2 of 10
JDMather
For some reason I get an error when attempting to extract your zip file.
Try these settings
From the images - the loads are applied in different directions in the two examples?
(Perpendicular to face in the one image.)
Without seeing the actual files - I would expect the load to be along the axis.
Message 3 of 10
16020227DHP
I tried another program to compress
password:1512
Message 4 of 10
mikejones
I get an error on both zip files
Autodesk Certified Professional
Message 6 of 10
JDMather
Windows OS always works for me.
Right click on the project folder and select Send to Compressed (zipped) Folder.
Is that what you did originally?
Message 7 of 10
16020227DHP
Ok i did with windows OS now
Message 8 of 10
JDMather
I did not find this Material Properties.
Message 9 of 10
16020227DHP
It's my custom properties,
i heard u can change into steel, mild for this for now
Message 10 of 10
Cris-Ideas
Results are different because these two analysis are different (obviously).
As you only provide very limited data, and I am not able to open the model as it is AI2023. I can only comment what I can see on the png.
1) deformation is different by order of magnitude or more.
2) Force values are not visibel
Possible causes:
1) structure is not the same. Scaled for example
2) material properties are not the same
3) Forces are different.
4) contacts are different for both simulations
5) bug in meshing if non linear constrains are used (there is a bug in inventor that makes results unstable in case non linear contact is used and gap between elements needs to be closed by the software. This combination does not work).
Cris.
Cris,
https://simply.engineering
