The more I use Inventor, the more unproductive I feel.
Well I'm completely the opposite. SlowlyWorks.
Do I right click or prees ESC to stop the command? Oh click on the corner.
Hi Todd,
Is this drawing created from scratch in 2018? There was indeed change in revision table height definition. In the past, revision table has its own height definition different than other drawing tables like partslist, general table, and hole table. The difference led to a lot of confusion. The change should not impact any existing revision table created from prior releases.
If you want, you can post an example here and I can help take a look. I have helped a few users adjust the old styled revision table to the new height definition.
Inventor is a CAD tool of choice. If it was so problematic to you, you might want to reconsider your choice. As long as you use Inventor, we are here to help.
Many thanks!
