What happened to C:\Program Files(x86)\Autodesk\Inventor Screenshot?
WHolzwarth
Mentor Mentor
Message 1 of 13
WHolzwarth
Is it no more working with Inventor 2022?
Walter Holzwarth
Replies (12)
Message 2 of 13
WHolzwarth
Right now I've seen Coolorange Screengrab in Autodesk Appstore. The menu is looking the same.
I'll give it a try.
Some time later: After two tiny changes it's working ok with 2022, too..
Walter Holzwarth
Message 3 of 13
cadman777
Walt,
I use FastStone Capture.
It's the best that I've seen.
Amazing what it can do.
I've made user manuals with it.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 4 of 13
spl1970
Can you explain how to get this to work please?
Message 5 of 13
WHolzwarth
It's depending on the active Inventor version.
For 2022, two changes are needed:
- In C:\ProgramData\Autodesk\ApplicationPlugins\coolOrange_screenGrab.bundle\PackageContents.xml Line6 change SeriesMax=Ir28"
-In C:\ProgramData\Autodesk\ApplicationPlugins\coolOrange_screenGrab.bundle\Contents\coolOrange.InventorScreenshot.Inventor.addin Line 9 changePackageContents.xml change
Line 9 to <SupportedSoftwareVersionLessThan>28..</SupportedSoftwareVersionLessThan>
Walter Holzwarth
Message 6 of 13
spl1970
Thanks Walter, worked a treat.
Simon
Message 7 of 13
spl1970
Scratch that, it didn't work as intended, it doesn't produce a white background.
Message 8 of 13
WHolzwarth
Hmm. Came in with white BG here ok.
Walter Holzwarth
Message 9 of 13
cadman777
Simon,
FastStoneCapture has a Draw option that allows you to fill the background with any color you want.
It's like Paint, but 1000x better at editing screen captures.
It has so many features that it's worth a try.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 10 of 13
WHolzwarth
Caused by another thread I stumbled in here today.
Strange observation:
- White background can be set in 2021
- Does not work in 2022
- 2023? I know, but I'm on NDA
Walter Holzwarth
Message 11 of 13
stevevanherk
Anyone got this working for 2023 version? Please let me know.
Message 12 of 13
johnsonshiue
Hi Steve,
All coolOrange Add-Ins can extend their support to more recent Inventor by changing the Add-In file mentioned above. Simply change the version to 100 and then it will work for many years.
Many thanks!
Software Test Engineer
Message 13 of 13
stevevanherk
I got it working now in 2023.
Thank you!
