What file folders and additional programs are necessary to use Inventor 2018?
Hi. I don't have exactly an specific problem with the program. I downloaded Inventor 2018 some months ago. Today I check my computer Storage and I see that differents programs like Autodesk Desing Review, autodesk inventor electrical catalog browser, A360 Desktop and they are ocuppying too much storage. But I didn't eliminate them because I guess that like any program Inventor needs additional folders and programs to function and this my doubt. Maybe I installed a product package of autodesk products. So, I only need to use the program Autodesk Inventor Professional 2018 by the moment. What file folders and additional programs are necessary to only use inventoe 2018?
Have a look inside C:\Autodesk. you could move these installer files to an external hard drive, as they are only used for installation or repair. The reason I say move and not delete, is that you do sometimes need them for installing updates or if you need to repair the software.
If you clear out C:\Autodesk, you should free up a LOT of disc space.
Have a look at this article: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Can-I-move-or-delete-C-A...
As for removing additional programs, you do need some of the installed components, you can get away with uninstalling the Revit Interoperability app (if you don't need it), as well as the Electrical Catalogue (again, if you don't need it). The best way to do this is via the uninstall app, see this link: https://clintbrown.co.uk/2020/04/16/autodesk-uninstall-tool/
CGBenner
@Anonymous
Welcome to the forums!  I hope that the information provided by @Anonymous helps you with your question.  If it does, please use Accept Solution when you have gotten the answer you need.  This helps other users find this answer later.  Thanks!
To help you get the most from these forums, >>here<<  are some good resources you should take a look at.  Also, take a look at our new Design & Manufacturing resources, like our Shop Talk forum.  This is where you can talk about anything you want, instead of just asking product questions like you do in this forum.  Enjoy, and let me know if you have any questions.  You can use the "@" and my username to tag me in a post (this works with any user).
Chris Benner
