Weld
Weld
I have 2 parts in an Weld Assembly. I cannot  get the Weld to work.I also added a fillet to part 1 to see if it would Weld but no difference. I was using the Groove Weld
What do i need to change to make it work?
Fred.
JDMather
Pick the chamfer and the flat face of the flat part and do not go greater than 4mm size.
JD, would you have a screencast for this weld
Fred
JDMather
Thanks JD
