Weld symbol selection
I have a drawing where I need to use weld symbols and I am unsure of the correct symbol to use. The lower 2 weld symbols in the snip below are the 2 I am unsure of. All they will be doing with this weld is fusing over the surface, no weld filler used.
Any help would be appreciated.
freesbee
...well, the question you are asking has not much to do with Inventor, as the selection of the welding symbol has engineering motivations. Inventor is here simply a tool to document the choices of the engineering team.
You can refer to the EN22553 for more details
EN 22553 abstractEN 22553 abstract
Massimo Frison
CAD R&D // PDM Admin · Hekuma GmbH
