Announcements
Weld symbol for corner weld
jay030195
jay030195
For the attached image, two tubes end cut at 45 deg are joint and grounded using weld. I was little confused of which weld symbol should I use?
blandb
I have always used a square Groove weld. Looks like || with the grind flat options.
https://www.google.com/search?q=what+is+a+square+groove+weld&rlz=1C1CHBF_enUS988US988&sxsrf=AJOqlzVA...
Autodesk Certified Professional
cadman777
For local fabricatos in the states, I typically use the Fillet & C2C text just to the right of the symbol.
C2C means Corner-to-Corner weld, which should be self-explanatory.
Whenever I make corner joints with structural shapes, I make them C2C unless it's impossible.
That's a very strong joint compared to internal fillet inside the corner.
For the faces of the tubing, I would specify a V groove symbol & prep-angle (usually 75° overall bevel like with pipe joints).
You have no choice on the inside corner weld, so that would be a simple Fillet symbol.
I don't ever show the weld prep on the actual part b/c it takes too much time and doesn't matter unless it affects the overall length of the part. But even then, the shop buys know what to do.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
