Weld pattern - can't choose any feature [Inventor 2018]
j.pavlicek
j.pavlicek
Hello there,
I'm trying to make circular pattern of the parts welded to the base (part). There is Pattern menu in Weld tab, so I expect that this is for making weld patterns (help leads to standard assembly pattern help page).
When I'm in the "Welds" enviroment, pattern are greyed out, so I created some welds (fillet) and hit the return button. Now pattern menu is availible. But I can't choose anything in the assemly. Moreover, when I select the Weld (in the browser) before, it tells me that: "Select set contains object that cannot be patterned".
Here is GIF:
Inventor 2022, Windows 10 Pro
Sorry for bad English.
Accepted solutions (3)
Replies (7)
-niels-
I don't have that much experience with welds, but i do add them for visual reference from time to time.
As you have noticed, pattern is greyed out when laying welds (in the weld sub-environment) so in order to make a circular pattern weld, you'll probably have to make use of the intermittency option:
Hope that helps, laying welds the way you want can be quite cumbersome...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
j.pavlicek
Thanks for answer, but intermittence option is not what I'm looking for. I need to weld X pieces of segments to base ring. Each of these segments is attached by two fillet welds. (How you can see on GIF in my initial post).
-niels-
Ah, ok... but that should be easy...
Add your segments with a pattern and then make your weld.
If i'm assuming correctly, then you can select your base ring as a first selection and then just select all the side faces of the segments that need a weld.
Like i stated, welds can be pretty cumbersome...
Niels van der Veer
The Netherlands
j.pavlicek
Oh, is this really only solution? Because there is plenty fo these segments = work for clicking monkey 😞
-niels-
From a quick test i did, i'd say it looks like it... Smiley Sad
I did a quick check over on the Inventor ideas, but couldn't find something specifically mentioning this workflow.
Only that the weldment environment could use some improvement...
I can certainly see the "click monkey" amount of work if you have a large pattern type product, so i'd suggest making an idea for this and reporting back here so people can cast a vote for it.
I know i certainly will. Smiley Wink
Niels van der Veer
The Netherlands
johnsonshiue
Hi! Indeed, currently Inventor does not allow weld beads to be patterned. I have heard the request before. Please take a look at Ideas Forum and vote for the idea. Or, submit a new one. Many thanks!
Software Test Engineer
j.pavlicek
Vote for: Pattern welds feature (Idea Board)
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
