Weird bubble around part that I can not access
As seen in the picture below there is a strange bubble round the part. This moves with your view and becomes solid if you try to section view the part. I do not know how to fix it and was wondering if someone could help. The file is attached so you can have a look at it closer.
mdavis22569
Where did you get the part from?
Can you share the original?
The original we might be able to remove it on the translation ...
Mike Davis
JDMather
See Attached.
Thank you. How did you do it? Or did it just work for you?
JDMather
@Anonymous wrote:
 How did you do it?
Repaired in Construction Environment.
