Weird behavior when entering characters with Japanese mode of IME in drawing environment
rom-8754
Message 1 of 10
rom-8754
Hi, I'm using Inventor 2020.3.4.
It happens at text edit dialogue in drawing environment.  When I use numbering mode and enter any single-byte characters with Japanese mode of IME, unnecessary number and space characters are inserted.  Please see the attached video in detail.
I think it's a bug and it annoys me sometimes. Are there any workaround? Do any Autodesk guys know this bug?
Thanks in advance.
da4890a1-6de0-4965-8cc3-f172bfb9e5e0,640,650
Replies (9)
Message 2 of 10
rom-8754
Why I couldn't post the video?...
https://autode.sk/3qm0zFN
Message 3 of 10
johnsonshiue
Hi! A quick thing to check. Go to Control Panel -> Region and Clock -> Region -> Administrative -> Change System Locale -> uncheck "Beta: Use UTF-8 Unicode for Worldwide language support."
This option seems to create issues in Inventor and AutoCAD. Please disable it.
Many thanks!
Software Test Engineer
Message 4 of 10
rom-8754
I checked the setting, it is unchecked (disabled).
So it seems not the cause. thank you.
Message 5 of 10
rom-8754
Does anyone have a solution?
Message 6 of 10
johnsonshiue
Hi! Have you tried resetting Inventor settings? Go to All Programs -> Autodesk -> Inventor 20xx -> Tools -> Inventor Reset Utility. It will reset all Inventor settings back to install default.
Many thanks!
Message 7 of 10
rom-8754
@johnsonshiue
Yes, I've reseted Inventor but the issue still happens.  Plus, I confirmed that it also happens another PC.
Message 8 of 10
johnsonshiue
Hi! Just a update on this issue, this has been confirmed as a defect specific to Japanese version of Inventor (INV21-1621). But, I cannot give you an estimate when it will be fixed.
Many thanks!
Message 9 of 10
rom-8754
It will be fixed sooner or later thanks to the your contribution.  When the any new updates come out, I will check whether this issue has been fixed or not.
Thank you!
Message 10 of 10
johnsonshiue
Hi! I need to clarify that. I really don't know when it will be fixed. I will let you know when it is fixed.
Many thanks!
