Weights from assembly
baliasM74U3
Message 1 of 17
baliasM74U3
HI Experts
Inv 2018
I have an assembly with 15 components. Can I select 5 of them and find out the mass of these items (combined mass of  components only)from the assembly environment ?
Replies (16)
Message 2 of 17
SharkDesign
Don't think so.
Couple of options.
Open BOM, add the mass column. Copy these into excel and do a sum.
Or
Create a new assembly, click the 'restore layout' icon next to the cross in the top right. This tiles the windows. Drag those parts from the browser in to the new assembly and check the mass in the iproperties.
  Inventor Certified Professional
Message 3 of 17
johan.degreef
@baliasM74U3
@SharkDesign
Set all the parts you don't want to "BOM structure - Reference" and check the mass again.
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Message 4 of 17
andrewiv
You could create a level of detail and suppress everything except the 5 components that you want to get the weight of.  When you perform a mass properties update it will ask if you want to calculate the mass of the master LOD.  You can click NO and it will tell you the mass of just the components that are not suppressed.
Andrew In’t Veld
Designer / CAD Administrator
Message 5 of 17
SharkDesign
If you're doing any of the methods above involving suppressing or referencing stuff do the following.
Click the items you want, click the filter and choose invert selection, then all the items you don't want are now selected.
You can now suppress en masse or reference.
Message 6 of 17
johnsonshiue
Hii! All above suggestions make sense. They are the only ways to do it in Inventor unfortunately. But, strictly speaking they are not what the OP was looking for. Any of the above workflow involves design change. What OP was looking for is a quick way to tell the mass prop of a group of components. The ability is available on Fusion 360.
Many thanks!
Software Test Engineer
Message 7 of 17
karthur1
@johnsonshiue wrote:
Hii! All above suggestions make sense. ..... The ability is available on Fusion 360.
Many thanks!
😞 😞  Too bad Inventor does not have the same tool for this.
Message 8 of 17
Curtis_Waguespack
Hi @baliasM74U3
You can give this ilogic rule a try.
I hope this helps.
Curtis
oConversion = 1
oUnit = " kg"
' 'uncomment this To use lbs
'oConversion = 2.2046
'oUnit = " lbs mass"
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oTotalMass As Double
Dim oList As New ArrayList
oSet = oADoc.CreateHighlightSet
While True
	oMsg = "Select parts (press ESC to continue) Total Mass " & _
	Round(oTotalMass * oConversion, 3) & oUnit
	Dim oOcc As ComponentOccurrence
	oOcc = ThisApplication.CommandManager.Pick(
	SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, oMsg)
	' If nothing gets selected then we're done
	If IsNothing(oOcc) Then Exit While
	'check against list to prevent
	'selecting same component twice
	If oList.Contains(oOcc.Name) = False Then
		oList.Add(oOcc.Name)
		oSet.AddItem(oOcc)
		Dim oMassProps As MassProperties
		oMassProps = oOcc.Definition.Document.ComponentDefinition.MassProperties
		oTotalMass = oTotalMass + oMassProps.Mass
End While
InputBox("Total mass in " & oUnit, "ilogic", Round(oTotalMass * oConversion, 3))
oSet.Clear
Message 9 of 17
karthur1
Curtis,
Sweet!  One thing I noticed is that if the assembly consists of both parts and assemblies, when you try to pick the items from the graphics window, it will only select "parts".  If you want to select the whole sub-assembly, you have to select this from the model browser rather then the graphics window. If you try to select all the items of a sub-assy from the graphics window, it can be difficult to include all the items.  There is no selection widow, but being able to select the entire sub from the model browser is key.
Also, there is no way to remove an item from the selection set.  Pick your items carefully.
Kirk
Kirk
Message 10 of 17
Curtis_Waguespack
@karthur1 wrote:
One thing I noticed ...
Hey that's 2 things! 😏
Thing 1:
So... I don't know how to allow the user to switch between selecting subassemblies and parts using the Pick method with iLogic... there might be a clever way to code that, but I've never figured it out...
the previous example was set to filter for "leaf occurrences" meaning it allowed the user to select parts from within the sub assemblies...  this example is filtering for "occurrences"... so it selects the entire subassembly
...but as far as I know it's an either/or choice as far as coding it
Thing 2:
This version removes a previously selected item, if it is selected again.... whereas the previous version simply disallowed it to be selected again.
Thing3 (bonus):
I changed the "feedback" to use the client graphics rather than the cursor tool tip, so you should see the weight and number of selected components in the top left of the screen, something like the image below... let me know if that doesn't display well... I've only experimented with using client graphics for this kind of thing in the past, so I don't know how well it translates to different monitor and display setups
I hope this helps.
Curtis
Sub main
	oConversion = 1
	oUnit = " kg"
	'	'uncomment this to use lbs
	'	oConversion = 2.2046
	'	oUnit = " lbs mass"
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	oSet = oDoc.CreateHighlightSet
	Dim oCollection As ObjectCollection
	oCollection = ThisApplication.TransientObjects.CreateObjectCollection
	While True
		oMsg = "Select components (press ESC to exit select)"
		SelectionFilterEnum.kAssemblyOccurrenceFilter, oMsg)
			oCollection.Add(oOcc)
		Else
			oList.Remove(oOcc.Name)
			oCollection.RemoveByObject(oOcc)
			oTotalMass = oTotalMass - oMassProps.Mass
		oLine1 = Round(oTotalMass * oConversion, 3) & oUnit _
			& " ; " & oCollection.Count & " items selected"
		Call WriteClientGraphics(oLine1)
		oSet.AddMultipleItems(oCollection)
	End While
	Call ClearGraphics
End Sub
Sub WriteClientGraphics(oLine1 As String)
	oFont = "Stylus BT"
	oFontSize = 35
	Dim oDoc As Document = ThisApplication.ActiveDocument
	' a reference to the component definition.
	Dim oCompDef As ComponentDefinition
	oCompDef = oDoc.ComponentDefinition
	Call ClearGraphics
	oClientGraphics = oCompDef.ClientGraphicsCollection.Add("Text Test")
	Dim oTG As TransientGeometry
	oTG = ThisApplication.TransientGeometry
	Dim oAnchorPoint As Point
	oAnchorPoint = oTG.CreatePoint(0, 1, 1)
	' Create a graphics node.
	Dim oNode As GraphicsNode
	oNode = oClientGraphics.AddNode(1)
	'[ Text1
	Dim oTextGraphics1 As TextGraphics
	oTextGraphics1 = oNode.AddTextGraphics
	oTextGraphics1.Text = oLine1
	' Set the text's anchor in model space.
	oTextGraphics1.Anchor = oAnchorPoint
	' Anchor the text graphics in the view.
	Call oTextGraphics1.SetViewSpaceAnchor( _
	oAnchorPoint, oTG.CreatePoint2d(40, 40), kTopLeftViewCorner)
	oTextGraphics1.Font = oFont
	oTextGraphics1.FontSize = oFontSize
	oTextGraphics1.PutTextColor(0, 0, 255)
	ThisApplication.ActiveView.Update
End Sub
Function ClearGraphics
	oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
	' Attempt to get the existing client graphics object.  If it exists
	' delete it so the rest of the code can continue as if it never existed.
	Dim oClientGraphics As ClientGraphics
	On Error Resume Next
	oClientGraphics = oCompDef.ClientGraphicsCollection.Item("Text Test")
	If Err.Number = 0 Then
		oClientGraphics.Delete
	On Error GoTo 0
End Function
Message 11 of 17
karthur1
Thing 1:
Thing 2:
Thing3 (bonus):
I hope this helps.
Curtis
Two things... yea, you know engineers cant add. 😁
Thing 1:  If figured that it was "either/ or".  I sort of liked the way it was originally, where we could pick single items from the graphics window, but if needed I could pick an assembly from the browser.  That would give me all the items in the sub.  That way you could have both.
Thing 2:  Excellent.  Much better!!!
Thing 3:  I like it. But if the background is the same color as your text, it might be difficult to see.
Kirk
Message 12 of 17
Curtis_Waguespack
ok, so here's a version that has some option that can be uncommented for selection and graphics colors, etc... this way folks can set the "things" up as they prefer. 🙂
Sub main
	'/////////// options
	oConversion = 1
	oUnit = " kg"
	'''uncomment these 2 lines to use lbs
	Dim oSelectionFilter As SelectionFilterEnum
	'subassembly selection
	oSelectionFilter = SelectionFilterEnum.kAssemblyOccurrenceFilter
	'''uncomment this line to use part selection
	'oSelectionFilter = SelectionFilterEnum.kAssemblyLeafOccurrenceFilter
	''' uncomment or change this to a named color scheme of your choice
	oColorScheme = "Light"
	'oColorScheme = "Sky"
	Dim oColor As Color
    oColor = ThisApplication.TransientObjects.CreateColor(0, 0, 0) 'black
	'''uncomment one of these to change text color
	''' or create your own RGB color values
	'oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0) 'red
	'oColor = ThisApplication.TransientObjects.CreateColor(0, 255, 0) 'green
	'oColor = ThisApplication.TransientObjects.CreateColor(0, 0, 255) 'blue
	'/////////// end options
	oCurrentBackground = ThisApplication.ColorSchemes.BackgroundType
	oCurrentBGName = ThisApplication.ActiveColorScheme.Name
	ThisApplication.ColorSchemes.BackgroundType = BackgroundTypeEnum.kOneColorBackgroundType
	ThisApplication.ColorSchemes(oColorScheme).Activate
	On Error GoTo ResetColors
	While True
		oSelectionFilter, oMsg)
		Else
		Call WriteClientGraphics(oLine1,oColor)
	End While
	Call ClearGraphics
	ResetColors :
	ThisApplication.ColorSchemes.BackgroundType = oCurrentBackground
	ThisApplication.ColorSchemes(oCurrentBGName).Activate
End Sub
Sub WriteClientGraphics(oLine1 As String, oColor As Color)
	oFont = "Stylus BT"
	oFontSize = 35
	Call ClearGraphics
	'[ Text1
	oTextGraphics1.PutTextColor(oColor.Red, oColor.Green, oColor.Blue)
End Sub
	On Error GoTo 0
End Function
Message 13 of 17
karthur1
I get this for the latest version.  Could not figure out where the error was.
Message 14 of 17
Curtis_Waguespack
hmmmm...I'm not sure, but it was probably something related to toggling the color schemes... but there might be some hiccups with using the client graphics that I'm not familiar with, since I've not used that all that much
here's two other versions....
  • a simpler version that just uses the tool tip and gets rid of all the color scheme and client graphics stuff
  • and one that gets rid of all the color scheme stuff, and just writes the info to the tool tip and client graphics both
I hope this helps.
Curtis
version that just uses tool tip
Sub main
	oConversion = 1
	oUnit = " kg"
	oMsg = "Select a component (press ESC to end selection)"
	While True
		Else
		oMsg = Round(oTotalMass * oConversion, 3) & oUnit _
	End While
	oSet.Clear
End Sub
version that uses client graphics
Sub main
	oConversion = 1
	oUnit = " kg"
	While True
		Else
		Call WriteClientGraphics(oMsg)
	End While
	Call ClearGraphics
End Sub
	oFont = "Stylus BT"
	oFontSize = 35
	Call ClearGraphics
	'[ Text1
	'oTextGraphics1.PutTextColor(0, 0, 0) 'black
	'oTextGraphics1.PutTextColor(255, 0, 0) 'red
	'oTextGraphics1.PutTextColor(0, 255, 0) 'green
	oTextGraphics1.PutTextColor(0, 0, 255) 'blue
End Sub
	On Error GoTo 0
End Function
Message 15 of 17
karthur1
I tested both and no errors on either.  I like the one that writes it to the tool tip.... just my preference.
Thanks again.
Kirk
Message 16 of 17
dlekx
Hi, I got this by reference from another thread.  I tried it and it works well.  Is there a way to have multiple-selection functionality?  (drag mouse and it picks everything in the window, shift-select in the browser window, etc)
Message 17 of 17
Cris-Ideas
It depends what is the purpose of your effort.
But if you only want a quick info I would suggest as follows:
1) select everything of interest for you (but this can only be components (parts or assemblies) of the top level)
2) Ctrl+C
3) open new assembly file
4) Ctrl+V
5) iProperties -> physical properties
This will be faster than playing with LoD and requiring less effort, and also it is easier than changing other parts to reference BOM, and you will not produce errors in your original model.
But if this is a solution for you it depends on what exactly is that you are after.
There are also other potential the like trick that come to my mind, but it all depend on the intent.
Cris
Cris,
https://simply.engineering
