Weight of part linked to size?
henryjoseph9804
henryjoseph9804
Hi everyone,
I need some help, I'm not sure if this is doable.
I have some mesh screens that are 110mm x 110mm. I have weighed them and assigned the weight to the piece.
I would like the weight to update as I change the dimensions, so that way I can estimate the weight for a 4m x 10m mesh screen.
How do I go about doing this?
JDMather
Assign a material with the appropriate density.
As the model changes - the weight will automatically update.
For example, surely you are not modeling your screen mesh as actual geometry (but rather, as a fully dense solid body with cosmetic screen appearance) - so you can't simply apply say steel material.  So you have to calculate a lower density for your custom "material" properties.
Once you have defined this special material - you can save to a library and use it anywhere.
Attach an example file here and indicate actual weight.
Frederick_Law
Setup new material with correct density for the mesh.
You can setup all different mesh.
Use Appearance to make mesh without cutting al the holes:
henryjoseph9804
Hi JD,
Thank you for the response!
No definitely not modelling it as individual geometry. I've learnt in the past this is too intensive on the system. I am using solid plt 1mm thick.
Please see attached part, I have copied a material, renamed it and played around with the density till I get the weight i measure on our scale.
henryjoseph9804
Hi Frederick,
Thanks for the response!
Yes I have been playing around with the density till the weight matches what I measured on the scale. I have attached the part in my response to JD.
