Hello!
I am wondering if there is a way for change the visual style of surfaces within an inventor assembly? Basically I am a design engineer and I often work with plants/buildings that have some models of their existing layout or equipment that I help design around. Often their Files import into inventor as surfaces not bodies because their model isn't 100% clean or whatever the issue is. My problem is that these surfaces appear on the screen as transparent all the time and the only way that I see them clearly is if I use the technical illustration visual style. Is there a way to make the surfaces appear like a solid would in the shaded visual style?
Thanks for any help!!
Inventor Pro 2021
