I'm trying to programatically create a relatively complex shape, and to do so, I need to create a work plane normal to an equation curve.
In the UI, I can easily create an equation curve, then create a plane normal to that curve at the endpoint. It works perfectly, and looks like this:
This is the equation (That was created programatically)
And I can add a normal plane to it, no problem.
But when I attempt to create the equation curve and plane programmatically, I get, "Invalid Procedure Call or argument"
I've attached a dummy part that contains the script. You can just run the script, it will create a demo line/curve based object, then an equation driven curve, then it will attempt to create normal planes. The first will succeed, the second will fail.
I think the AddByNormalToCurve is being too restrictive. The docs say, "For a 2D sketch entity, the geometry must be a Spline2d, Arc2d, Circle2d, EllipticalArc2d, or Ellipse2d", but I believe that equation curves should work as well because they do from the UI.
Am I simply missing something, or is there a deficiency in the API?
-Caleb
(Just in case the part doesn't work right, you can just try out this code... it's the important bit of the part anway)
Private Type SnailStructT eqCurve As SketchEquationCurve line As SketchLine End Type Sub createSweep() Dim invDocs As Documents Dim currentDoc As Document Dim docType As DocumentTypeEnum Set currentDoc = ThisApplication.ActiveDocument Debug.Assert (currentDoc.DocumentType = kPartDocumentObject) Dim currentPart As Inventor.PartDocument Set currentPart = currentDoc ' create a sketch Dim partDef As Inventor.PartComponentDefinition Set partDef = currentPart.ComponentDefinition Dim xyPlane As WorkPlane Set xyPlane = partDef.WorkPlanes.Item(3) Dim sketch As PlanarSketch Set sketch = partDef.Sketches.Add(xyPlane, False) ' Create some lines (from the demo) Dim plane1 As WorkPlane Dim plane2 As WorkPlane Dim snail As SnailStructT snail = dumbThingy(sketch) Dim o As Object Dim p As SketchPoint Set plane1 = partDef.WorkPlanes.AddByNormalToCurve(snail.line, snail.line.StartSketchPoint) ' Create an equation curve Dim snail2 As SnailStructT snail2 = createSnailSketch(sketch, "20mm", "360 * 2", "360 * 2.25") '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' ' everything works up to this point... but then this fails.' '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' Dim c As Object Set p = snail2.eqCurve.StartSketchPoint Set c = snail2.eqCurve Set plane2 = partDef.WorkPlanes.AddByNormalToCurve(c, p) End Sub Private Function createSnailSketch(sketch As PlanarSketch, _ r0 As Variant, _ startAngle As Variant, _ endAngle As Variant) As SnailStructT sketch.Edit Dim tg As TransientGeometry Set tg = ThisApplication.TransientGeometry Dim eqCurve As SketchEquationCurve Set eqCurve = sketch.SketchEquationCurves.Add(kParametric, _ kPolar, _ r0 + "*pow(2.618;t/360)", _ "t", _ startAngle, endAngle) Set createSnailSketch.eqCurve = eqCurve sketch.ExitEdit End Function Private Function dumbThingy(sketch As PlanarSketch) As SnailStructT sketch.Edit Dim tg As TransientGeometry Set tg = ThisApplication.TransientGeometry Dim p1 As Point2d Dim p2 As Point2d Set p1 = tg.CreatePoint2d(0, 0) Set p2 = tg.CreatePoint2d(5, 0) Dim lines(1 To 4) As SketchLine Set lines(1) = sketch.SketchLines.AddByTwoPoints(p1, p2) Set p1 = tg.CreatePoint2d(5, 3) Set lines(2) = sketch.SketchLines.AddByTwoPoints(lines(1).EndSketchPoint, p1) Set p1 = tg.CreatePoint2d(4, 3) Set p2 = tg.CreatePoint2d(4, 4) Dim arc As SketchArc Set arc = sketch.SketchArcs.AddByCenterStartEndPoint(p1, lines(2).EndSketchPoint, p2) Set p1 = tg.CreatePoint2d(0, 4) Set lines(3) = sketch.SketchLines.AddByTwoPoints(arc.EndSketchPoint, p1) Set lines(4) = sketch.SketchLines.AddByTwoPoints(lines(1).StartSketchPoint, lines(3).EndSketchPoint) Call sketch.GeometricConstraints.AddHorizontal(lines(1)) Call sketch.GeometricConstraints.AddPerpendicular(lines(1), lines(2)) Call sketch.GeometricConstraints.AddTangent(lines(2), arc) Call sketch.GeometricConstraints.AddTangent(lines(3), arc) Call sketch.GeometricConstraints.AddParallel(lines(1), lines(3)) Call sketch.GeometricConstraints.AddParallel(lines(4), lines(2)) sketch.ExitEdit Set dumbThingy.line = lines(1) End Function
Hi Henry,
I can reproduce the error and report it as INVGEN-20942, you can provide this number to query its status later.
