Vault side tab is getting small every time
b_ruijter
b_ruijter
Since we have been working with Inventor 2023 i have this problem
 When i open a file the Vault side bar is totally small.
I slide it up to view the vault browser.
Every time i clos the file and open again, the vault browser is desaperar again.
Is this a bug?
  • 2023
sundars
Hi @b_ruijter
Is this the release version of 2023 or a beta version?
I just checked - In 2022, the vault browser disappears on file close. On new file or when opening an existing file in a vault project, the vault browser comes back. Same behavior in 2023.
You could try the following:
1. Open some file
2. Setup your vault browser and position it where you want it to be
3. Shut down inventor
4. Restart
5. Reopen your file
6. Check to see if the vault browser retains its position.
If not, would you mind posting a video of the problem?
-shiva
Shiva Sundaram
Inventor Development
b_ruijter
It's the releast version of Inventor 2023.
In your scenario, the vault bar position remainson position!
I see now the problem still remains. It accurs when i open another file beside the first. I'll make a video.
https://www.youtube.com/watch?v=O6RmlIAyquo
JarFu
hi @b_ruijter,
I saw the problem in the video but I couldn't reproduce it on my side with Inventor 2023 RTM (or 2023.0.1) + Vault now. The issue you showed is very similar as the problem we fixed before in Inventor 2021- Internal ticket INVGEN-29358: Up-down docked browsers will be resized to minimized wrongly in some cases.
Could you please help try if Reset UI Layout can help? You can find it from View> Windows or Tools> Options dropdown.
Jar Fu
SW Engineer
Inventor QA
Autodesk, Inc.
b_ruijter
Hello @JarFu ,
It did not solve the problem.
But I noticed sometimes I can switch from ipt to iam and back, no problem, but every time I go to the home screen the vault tab drops.
Is this something you can reproduce?
