Vault Properties not showing up in Inventor File Properties
I'm using CNTRL-E to mass edit and change multiple properties in Vault Pro, but those changes to the properties do not show up in the Inventor .ipt file or parts list in an Inventor .idw file.
The Vault Category is configured correctly with the applicable properties assigned.
Mapped the properties in Vault thru Vault Settings/Behaviors/Properties/etc.
Observation 1: In the Edit properties Dialogue box, on the Mapping Tab, even though I only have one mapping, down below on the Where Used Tab, it lists 2 File Entities, the one on top has the double arrow (Synchronize values between Vault property and file property), and the one below has the (Extract value from source file and writes into the Vault property) The arrows are grayed out so I couldn't reorder them if I wanted to. Why would I have only one mapping but then get these two entities? This happened the first time I created this new property, so I deleted the mapping and started over and the same two entities popped up again?
Observation 2: I can open a .ipt file in IV. Open up iProperties/Custom Tab, and it will show no properties. But then if I open up iPropWiz, it will list all the properties, but they will be blank. Looking at my other screen with Vault, you can clearly see all the properties filled in. If I hit Apply in iProp Wiz, THEN go to iProperties/Custom Tab, it is now populated with the Name of the properties, but they are all still blank. If I then manually type the properties into either iProperties/Custom tab OR thru the iPropWiz (ive done both ways), and then save and check in the file, THEN those values now show up in Vault.
Now if I then CNTRL-E, change a property value in Vault, then immediately open up that file in IV, it doesn’t show the property updated. If I click Update Properties nothing happens. If I open up iPropWiz, its not updated. It is only when I click on the iProperties icon that the message ‘file has been updated outside the current session’ message. I click Yes and then the properties are updated.
Thanks for help.
