Vault LogIn
This widget could not be displayed.
Vault LogIn
Everytime I open an assembly drawing which needs parts to be resolved, the vault auto login appears and repeatedly appears even when dissmissed, Inventor then seems to prioritise this rather than opening the assembly, is there anyway this can be stopped?
jletcher
We will need more information then this.
1. What version of Inventor.
2. Do you use Vault
3. Service Packs
Not sure I can understand what you are trying to say here.
It seems like you are saying when you attempt to open an assembly drawing you are being asked to log into Vault but yet you keep dismissing (cancelling) it.
It can be stopped by simply loging into Vault before you attempt to open the assembly drawing from Vault.
It makes sense if you think about it, the file you are attempting to open resides in Vault. In order for you to access it (open it), you need to be logged into the Vault.
The door to your house is locked, you are attempting to get in, how would you open the door? With your key!
How far off am I on this?
