Vault Error when using Copy Design: Value cannot be Null. Parameter name: path2
I'm trying to get copy design to work on a big assembly we have but it pops up with a dialog box saying:
"Value cannot be Null. Parameter name: path2"
I've got my working folder properly set in C:\Vault Workspace. Some of the sub assemblies in this big assembly don't get this error when I use copy design. Anyone know of a fix?
mdavis22569
Take a look at :
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
you also might want to ask this question on the Vault Forum
http://forums.autodesk.com/t5/vault-general-discussion/bd-p/101
Mike Davis
Curtis_Waguespack
chuck.bardsley
I just had the same error. I was able to determine that the culprit was a .ipt which was derived from another ipt that no longer exists.  I broke the link to the derived part and the error went away.
Chuck B.
johnsonshiue
Hi Chuck,
This sounds like a bug to me. I guess Vault Copy Design detect a potential cyclic relationship and then error out. The bug is not with Vault. It is likely in Inventor that such cyclic relationship was allowed at a time. Please feel free to share an example that exhibits the behavior. Something is wrong. You should not need to break the link in order to copy files.
Many thanks!
Software Test Engineer
