Vault Basic Client 2022
williamCEH3B
williamCEH3B
Hi.
I have recently started using Vault Client 2022.
I've set up a search criteria to check for checked out files.
In the find interface it returns the querry (as shown below)
When i use the search folder nothing is checked in (as shown below)
My settings is set up as exactly the same as the administrator and his search folder is the correct checked in.
Gabriel_Watson
Do you have a filter applied?
Verify if you didn't apply an additional filter on top of your search:
https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2022/EN...
williamCEH3B
Thank you. It shows correctly now.
