Variable Fillet modeling failure
PuLsar_11
Message 1 of 10
PuLsar_11
I've been trying to create a variable fillet between two objects and I just keep getting errors.
I attached the file, I'm sure that that will be the best way to troubleshoot.
All of these approaches have failed.
Workflow one:
  1. copy both parts from assembly to new part file (create new solid)
  2. delete undesired faces (with heal checked)
  3. create fillet
Workflow two:
  1. copy both parts from assembly to new part file (create new multiple solids)
  2. combine both parts
  3. delete undesired faces (with heal checked)
  4. create fillet
Workflow three:
  1. create the files from scratch as one solid
  2. delete problematic faces (with heal checked)
  3. create fillet
Accepted solutions (3)
Replies (9)
Message 2 of 10
MSD_takaseh
Hello PuLsar_11,
How about a way here?
It should be needed same way for opposite side.
Hitoshi Takase
Message 3 of 10
PuLsar_11
Worked great, thanks!
Message 4 of 10
johnsonshiue
Hi! Here is another solution using Surface Modeling technique. Please take a look and see if it works for you.
Many thanks!
Software Test Engineer
Message 5 of 10
Mr. Takesh any way you can explain to me why the creation of this fourth and last fillet is failing?
I tried everything descripted in forums plus the aproach shown by you and those taken by pulsar. Im about to throw my comouter to the wall Smiley LOL
Thanks in advance
Message 6 of 10
VChampDK
There's a very tiny groove between the two faces. Delete/Heal it and you're fine 🙂
Peer
Iv2018/Vault Professional 2018
Lenovo ThinkStation P720
Intel Xeon Gold 5122 - 3.6GHZ
32GB RAM - Win10/64Bit
Lenovo Thinkvision 27"; 2560 x 1440
nVidia Quadro P2000 - 5GB 25.21.14.1771
3Dconnexion SpaceNavigator 10.5.4
Message 7 of 10
I tried but it wont work! you can see from the left side that i tried patching healing and stitching to no success...   😞
Please help me
Message 8 of 10
johnsonshiue
Hi Juanita,
I am sorry I have to say I don't understand the design intent of Extrusion 8 and also the rest of Delete Face + Boundary Patch + Stitch. Why does Extrusion 8 create two holes? Shouldn't the profile be smaller? Why do you need to delete planar faces and then add boundary patches?
Many thanks!
Message 9 of 10
HI Johnson,
The design in question is show bicycle stem. Extrusion 8 is just a weight reduction that also serves as a hole fore aerodynamic cable routing.
The last steps in the piece were just intents to heal the part as above was described to have a tiny gap... but i failed.
If anybody can help me out to carry out that last fillet would be great; either through solving it and leaving the file for me to examine the route taken or though teaching me! anything works and I´d appreaciate both.
Thanks in advance!
Message 10 of 10
VChampDK
Here you go 🙂
Peer
