Variable array
Variable array
steven.coxVCM6J
Message 1 of 9
Variable array
steven.coxVCM6J
Hi All,
I hate writing this post because there is a lot of solutions here, but I cannot seem to figure this out.
I want to create an array in an assembly that has a Max Spacing and is based on the width.
Ceil() and this unitless issue seems to be tripping me up.  However, I am also using an imported Width parameter.
I will use this same setup in multiple locations (i.e. _Top) so it will be very useful to make work.
I am pretty sure I saw a video on this once but cannot get YouTube on my work computer!!!
Thanks so much for the help,
Steven
Replies (8)
Message 2 of 9
kacper.suchomski
Hi
In your equation there is a division (in/in) which logically cancels out the units.
Kacper Suchomski
Message 3 of 9
steven.coxVCM6J
So why does the Ceil(Width / BF_MaxSpacing_Top) - 1ul Not work?
Or will that not accomplish what I want?  Maybe I am going the wrong direction.
Thanks, Steven
Message 4 of 9
steven.coxVCM6J
I guess one important note I left out of the original post is that I want to equally space BF across the Width.
Just more Parameters I supose.
Message 5 of 9
andrewiv
Your instance count has to be an integer if you want to use it as a value for a pattern.  I would set the formula to Ceil(Width/BF_MaxSpacing_Top)+1.  Then your spacing formula can be Width/(BF_InstanceCount_Top-1).
Andrew In’t Veld
Designer / CAD Administrator
Message 6 of 9
steven.coxVCM6J
For some reason the InstanceCount formula does not work.  What am I missing?
Thanks, Steven
Message 7 of 9
CCarreiras
must be :
ceil
not:
Ceil
CCarreiras
Message 8 of 9
andrewiv
@CCarreiras is correct.  That's my mistake, ceil cannot be capitalized.
Andrew In’t Veld
Message 9 of 9
steven.coxVCM6J
You have got to be kidding me!!  I knew it was going to something I was overlooking but never expected that.
Thanks so much!!!!!
