10:59 PM
What is the right workflow if you have an assembly with multiple identical valves, but they need a different TAG number (from P&ID). Physically it is only 1 ipt-file used for all the valves, so custom iProperty "TAG" will be the same in all valves. Should i copy/rename the ipt-file for each instance of the valve?
