Hi!
I am creating V-Belt using design accelerator.
I use inventor 2021.
I have had created the V-belt assembly and then I have deleted it.
Now, when I try to create the new one I can't select the standard for V-Belts,
The window is empty
Here is the screencast https://autode.sk/32D608R
The assembly is attached.
Thanks!
Hi! I believe the issue is that the Content Center Libraries are not properly installed on your machine or the libraries are not configured properly. Close all files and go to Get Started -> Project -> Configure Content Center (the button on the right at the bottom). Make sure all libraries are available and included. If they are not there, run Inventor Setup again to include the library files.
Many thanks!
@johnsonshiue hi!
You said --d go to Get Started -> Project -> Configure Content Center--
Do you mean this?
If yes, it works fine.
If I start a new assembly in a new project it also works fine.
So, believe that this is a small checkbox somewhere in the desert of the project))
@JDMather hi
Do you have any ideas?
And now, when I create pulleys and I can't see them at all.
Here is the image
and here is the screencast https://autode.sk/3sKVuXw
the assembly is attached
Thank you!
In your video - you are clicking in the wrong location.
In your video - I never saw you click where prompted?
Well, actually I don't know what I supposed to say in the situation.
I think it's a funny story.
Thanks!
