Using the hole command to do press/slip fits
I'm trying to make it easier for our engineers to add properly sized and dimensioned press/slip fit holes in our parts. We want to show our press/slip fit holes as a nominal thru hole and a counterbore which is the ream size for the press/slip fit. Someone tried adding press/slip fit holes to the clearance.xls but it's not quite working out. I've tweaked it a little and found what seems to be a limitation with the hole command possibly.
The first issue is when I select the counterbore option all sizes below 1/4" disappear from the drop down. I'm guessing Inventor thinks holes under 1/4" don't get counterbored and hides anything smaller, which seems like a weird restriction.
Second issue being the hole command is rounding my 4 decimal ream size to 3 decimal places. In the attached picture you can see some entries in my clearance.xls, the hole command where I selected the 1/4" option, and a drawing which also shows how it rounds the counterbore (ream) diameter.
These two things are making it look like we will just have to manually enter the dimensions in the hole command unless someone has a method for doing something like this. I've also though about using ifeatures or a vba script. The issue I have with ifeatures is having to insert them one at a time and dimensioning them each separately. I'm not aware of a method to insert multiple ifeatures at once on center points outside of sheet metal punch features. As for the vba route I'll just need to find time to code something easy to use.
