Using Part models to create another model
matt_johnson35
matt_johnson35
Hey Guys,
I'm trying to create a "foam" part that will fit under a shroud that has a number of contours, is there a way to create those contours on the "foam" piece using the shroud?
Matt Johnson
CAD Project Development Specialist
Inventor 2014
JDMather
Sure.
Multi-body Solids
or
Derived Components.
Can you attach your *.ipt file here?
matt_johnson35
I can't, I asked the customer and they didn't like the idea of me putting it online, because it's new model stuff, sorry. But thanks for the info I will try those two options.
Matt Johnson
Inventor 2014
JDMather
Can't you make up a dummy file to attach here that could be used to demonstrate the techniques?
