Using Parameters to control Form properties?
To expand upon the title, I want to control say, the max for a slider on a form with a parameter instead of a static number.
As you can see I have a Height parameter and I want to input it as the max value for a slider on a form
Unfortunately I get this error. Is there anyway to input a parameter into a form property?
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
I don't know of a way to control the Min and Max of a slider by rule, it seems a parameter of MAX will not work in the input "MAX is not a valid value for Double."
You can set it up to give an error and limit the size but not with a slider:
Define Min/Max of iLogicForm Slider with paramters
There is a limit range that will allow the slider but not go below the set values:
Limiting the Range of a parameter in Inventor Professional
Hope that helps!
Please select the Accept Solution button if a post solves your issue or answers your question.
johnsonshiue
Hi! Kelly's workflow is brilliant. I think this is the only way to have a dynamic range. I am marking his replay as the solution.
Many thanks!
Software Test Engineer
Thanks for the reply.  Using iLogic to limit sliders is what I ended up doing, but I have some parameters that are very variable and it seemed to defeat the purpose of a slider to have a 50 unit slider that only used 10 and vise versa.
kelly.young
Autodesk Support
Autodesk Support
@Anonymous I think this is just a limitation in the slider properties.
If you want to submit at Inventor ideas and post back here I'll give you the first vote.
SharkDesign
I've been doing pretty much the same as the link above but I also add in a messagebox otherwise the user doesn't know why the slider keeps jumping to a value they did not select.
If Parameter < ParameterMin Then
Parameter = ParameterMin
MessageBox.Show("Value Too Small." & vbCrLf & "Reset To Minimum.", "Min/Max", MessageBoxButtons.OK, MessageBoxIcon.Stop)
ElseIf Parameter > ParameterMax Then
MessageBox.Show("Value Too Big." & vbCrLf & "Reset To Max.", "Min/Max", MessageBoxButtons.OK, MessageBoxIcon.Stop)
Parameter = ParameterMax
Another option if you only have ten possible outcomes is to just add all ten values as a multivalue parameter, then use a drop down instead of the slider. Then it doesn't even need to calculate min and max. Unless of course this changes.
  Inventor Certified Professional
