USING PARAMETERS FOR A ROCKER BOGIE HELP
Message 1 of 9
So I m trying to optimize a rocker bogie suspension system but I am running into a few problems using the parameters. I am having problems with my parameter "L4" it should be a Patagonian equation for a triangle length: (S1^2+(2R))^(-1) but when I try it on my calculator I get different values then the nominal. I also get the text in red. I hope this is the cause for it not being able to finish the constraints since i am fairly certain my parameters I derived are correct. I attached images of what I am trying to do and what the inventor software is showing
thanks, Sage Edwards
CORRECTION: found that I can define L4 as L4=H1
also the angle between the bogie arms is constrained to 90deg
Update: I am thinking i need to revisit my equations but if i can get an explanation for the red text that would be great
Replies (8)
Message 2 of 9
JDMather
It doesn't look to me like you have accounted for your units.
I recommend that you right out the equation on paper with the units included.
Message 3 of 9
my equations are not dependent on units they are just basic trig and geometry equations. I am checking my equations on paper now but that doesn't explain the red error text. Did I type it in wrong?
Message 4 of 9
Additional question: I would like to make R (radius of wheel) to be a variable) Is this something I can do?
Message 5 of 9
JDMather
@Anonymous wrote:
my equations are not dependent on units ....
R is in mm
S1 is in mm
L4 is mm
Inventor doesn't forget the units.
I am doing some experimenting, I suspect that you cannot use implied negative ^-1ul
Message 6 of 9
JDMather
R is in mm  You have R=100mm which you are then squaring
S1 is in mm You have S1=286.706mm which you are then squaring
L4 is mm
Message 7 of 9
ok thankyou i didnt see anything for squarroots so i just did that
Message 8 of 9
Dear sedwar22,
Putting a quantity to the negative first power divides one by the quantity.  x^-1 = 1/x
What you would want to do to take the square root in the parameters is use the sqrt() function.
You might also want to re-enter your argument and put parenthesis around the powers. sqrt((S1^2ul)-((2 ul*R)^2))
Message 9 of 9
whoops i meant to have it to the power of 1/2 lol but yes i have tried putting the powers in () but thanks for the sqrt function i didnt know it was used here since i didn't see it on the list of commands i could use. but thanks i will give it a go
