Using iLogic to change model tolerance
Groentje
Groentje
Hello, i'am trying to change a tolerance in the model (ipt) by using Ilogic.
When i use:
then the value in the tolerance is multiplied by 10
When i use retrieve dimension in the drawing (idw) the values from the tolerance show +20 / -20 (also multiplied by 10)
Is this a bug in inventor or is my knowledge poor?
Curtis_Waguespack
Hi Groentje,
Inventor's internal unit is centimeters, so it's reading 2 as 2 cm's (when your document settings > units is set to millimeters).
You can do this to ensure that it reads it as mm:
Parameter.Param("d0").Tolerance.SetToDeviation(tol1 & "mm" ,tol2 & "mm")
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
