Using Direct Edit to non-uniformly scale a part with a small-scale value
lis_wang
Message 1 of 8
lis_wang
I want to scale the part in X direction in 0.9, Y direction in 1 and Z direction in 1.1. However, after scaled the part, I measure the sizes in X and Z direction, it does not change. When I change the scale from 1.1 to 1.2 and 0.9 to 0.8. The size changed. I attached my file here. I am using Invnetor 2025
Replies (7)
Message 2 of 8
Alexander_Chernikov
You can try to do this operation sequentially:
Set the coefficient for x - 0.9, "Apply",
then for z - 1.1, "Apply"...
Very strange behavior of the model.
With a coefficient of 0.9 for x and 1.1 (for y and/or z) the model rotates instead of scaling (Inventor 2025.3).
If x is not 0.9, then everything is fine...
For attention
(view in My Videos)
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 3 of 8
lis_wang
Yes, X scale cannot be 0.9. When I changed to 0.8999999, everything is fine
Message 4 of 8
This problem is also in version 2021+ and up to 2026
Facebook | LinkedIn
Message 5 of 8
johnsonshiue
Hi! This is a bug. It seems to have something to do with the sum of the non-uniformed scaled factors. For example, set X = 0.8, Y = 1, and Z = 1.2. The body will also flip. I will work with the project team to understand it better.
Many thanks!
Software Test Engineer
Message 6 of 8
lis_wang
ok. Thanks
Message 7 of 8
lis_wang
Message 8 of 8
johnsonshiue
Hi! This has been confirmed by the project team and reported as INVGEN-84637.
Many thanks!
