Using a single user parameter to dimension in different units of measurement
jhoneywillS7YJ7
jhoneywillS7YJ7
Hello all,
I would like to use a single user parameter to inform 2 different dimensions which each use a different unit of measurement.
EG. If parameter "x"=30, then I would like d1=30mm, and d2=30deg. I want to do this so that I can make an iLogic form to manipulate parameter "x" with a slider control, and I would like d1 and d2 to be informed by this change simultaneously, without needing to adjust each dimension separately. Does anyone have any ideas how this might be accomplished?
Thanks a lot
Jake
Tom_Sturtevant
Hello -
You can make X a unitless parameter and use "X * 1mm" to convert it to mm.  Like this:
Hope that helps!
T.0.M.
Tom Sturtevant
Inventor Part Modeling Developer
Autodesk, Inc.
